I am working on a friends 2008 Vector LTX and the primary weights are shot. I do have a set of heavy hitters that are almost the same weight as currently set up. I am wondering if anyone is running the heavy hitters and what they are running for a weight set up and primary spring.
The original weight is good in profile.
The clutch spring green-silwer-green large rollers (17mm) are required for this spring,
to a variator with a white bow with a standard helix of 70 degrees.
