2009 Apex, Spark plugs
BR*
Fergus, Ontario, Canada
Hey, what is the easiest way to change the spark plugs on my Apex, I tried , loosened the bolt but the cap will not come off,
thanks for your help.
I just did mine and found if you twist cap and then you can get a small heel bar under and lift. When reassembling I put some dielectric grease on boot to make it easier next time to remove.
