Skeeterzx225
Granted i'm not the biggest guy, but I have to put my feet all the way back and throw my weight back at takeoff to get any kind of front ski lift. I don't want major wheelies, but the ability to throw one when I want to would be nice. How can I setup my RTX SE to do this? Adjust the transfer strap? Up/Down?
yukon yamaha
- Jan 30, 2008
- WHITEHORSE, YUKON CANADA
- 2008 nytro custom! 2014 viper custom
let the limiter strap right out on the front of the skid, it will help
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
A few other things you could do:
Increase spring pressure on front suspension shock
Tighten rear limiter strap a hole or two
Lower compression on rear shock
Lighten torsion springs
Remove plastic transfer blocks near rear axle
Rev-it
I weigh 245 and on the hard packed trail I can stand my RTX on the snow flap, not for very far as it looses traction and drops back down but impressive. I dont touch the suspetion because it lifts the skis enough in the corner if you think of giving it power. I stand at the back pin the trottle and as the engine starts to spool up I move my weight up and plant it down on my feet kinda like a small jump BLAM instant wheelie. Now the 1.75 outback I'm getting will make it hole the wheelie.
Mine comes up pretty easily too - especially if I time a small bump right and am already moving at about 10 MPH. It stands right up on the rear bar - but I haven't pushed it as I'm afraid I'll bend the tunnel back there. It'll stay up for awhile though with my weight shifted back and little blips on the throttle.
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
Its pretty funny i weigh 220 w/o gear and my little bro weighs like 140 and with him on it will set back on that tip up with the skis about a foot in the air all the way to 65mph
Apex2006
- Oct 26, 2009
- McHenry, IL
- Yamaha Sidewinder SRX-LE 2019
Yamaha Sidewinder XTX 141 2017
Yamaha Viper XTX 2015
Yamaha Sno Scoot 2018
Ski-Doo Renegade XRS 850 2020
Loosen the limiter straps. I had to tighten it up because it lifts to much and I don't want the ski lift on the tight trails in the woods. But if you drop a couple of holes on the limiter strap you can wheelie all day!
Rayman5271
- Oct 3, 2009
- Northern Maine
- 2016 Yamaha SR Viper XTX SE
I dont think it's so much the straps... of course it will help but when it comes right down to it its traction. In the right snow I can stand back and ride a wheelie for a couple hundred feet. I'm not talking skis off the ground im talking almost vertical... I can throw the sled right over backwards if I wanted to... in fact this past weekend I was riding a wheelie and lost control and had to bail so it wouldnt roll. All in good fun I guess. My straps are setup for trail riding so I have no ski lift... but if you have a good hookup this nytro will rip them up no matter where your strap is.
mcamzr
Skeeterzx225 said:Granted i'm not the biggest guy, but I have to put my feet all the way back and throw my weight back at takeoff to get any kind of front ski lift. I don't want major wheelies, but the ability to throw one when I want to would be nice. How can I setup my RTX SE to do this? Adjust the transfer strap? Up/Down?
Before you make any adjustments. When you Take off do you have excessive track spin or does it hook up and go but leave the skies on the ground? I only ask because if it hooks up you don't need to change much to get what you want, I would maybe start with the center shock or rear strap. But if it trenches I would start at the front straps. If you can change one thing at a time and test it out. If it were me and it has been I would try each adjustment alone and to see what they do and then take what I liked about each and try them togather. It takes a bit longer but it's better than pulling the skies up in a field and loving it and then pulling them up in a corner and putting it in the trees.
