LesT
- Dec 30, 2018
- Bracebridge
- 2009 Yamaha Vector LTXGT
Hey folks...new member and hoping you might be able to assist a bit.
Just bought a used 2009 Vector LTXGT which I thought was in excellent shape but I blew a bogey before the first tank was through.
Rear left side and it appears the bogey may be cracked as well. Removed nut and dead wheel bearing. No movement when I removed nut and bearing remains.
I have checked all other wheels and they seem good.
Can I simply purchase a new bogey, slide on and tighten? Sounds too easy to me which is why I am here.
Tx in advance!
Tx in advance!
RAMSOMAIR
Yes, just put a new rear wheel assembly on. Wheel c/w bearing.
tommyt5078
Get the newer style, i think it came out in 2010.....then you can just replace the bearings! And cheaper!
LesT
- Dec 30, 2018
- Bracebridge
Thanks... I will check into replacing both outside bogeys then.
Had the choice between this and an Apex and extremely happy with the LTXGT as the snow and forest behind me consists of hundreds of acres of untouched wilderness... This machine goes anywhere... No trail needed . Probably should have held out for the next year and EFI but this machine runs amazing.
