2009 venture GT slipping out of reverse
Bowhunter
Mars sand hills
The end of last season my venture on occasion would slip out of reverse especially when you had to apply some throttle, new it seems to be worsning, is this just a simple adjustment or do I need to take it in, thanks for any advice/help.......Jason
That is correct....only adjustment.
You must tight the levers just before the point it touch the shifter wheel.
under the right panel by the Chaincase cover is a little rod about 4 inches long , loosen both lock nuts and twist shaft one way or the other , one way makes it better , one makes it worse , tighten lock nut , mine only took 2 turns or so
MM
MM
You don't have to disconect the rod to turn it?
thanks guys, was not sure because I tried tuning it by had and couldnt, pliers must be needed, will try again.
