FLOYD
- Aug 22, 2015
- michigan
- Yamaha nitro xtx turbo
2010 Yamaha nytro xtx turbo 144" what is the best clutch kit ??????
Is it ulmer clutch kit...or . Schmitt clutch kit..... those are the two major kits I know of
I am located in Michigan ,running on 10lbs of boost at sea level push turbo kit keep hitting rev limiter ?????
thanks
thanks
m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
Also had the same issue with my XTX and MPI SuperCharger. I'm still using all the stock weights and spring. MPI sells a selection of steel rivets to replace the stock light weight ones. I'm using three of there heaviest rivets in all three weights. Works great now and was inexpensive.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Go with the ulmer one, I have ulmer clutching on my turbo sled, works great. He will give you a baseline which should be pretty close (if not perfect) and you can fine tune the clutch weights yourself for the correct rpm.
meskie
Yup. Ulmer clutch kit in mine and very happy with it. Way better then the mcx weights that came in the turbo kit.
P.S. I have some slightly used MCX weights for sale.
DWhitney
- Mar 1, 2015
- Davison, Michigan
- 2012 Nytro XTX
I have the same sled with the same question. Talked to Ulmer and he said 4 washers at heel, 2 at mid, and 4 at tip. Is thst each side of the arm or total? I did it on each side...8 at heel, 4 at mid and 8 at tip. Weighed the arm and its only 70g?? Is this correct?
