Sno Cat
Does anyone know what the wet weights are for:
'11 Apex
'11 Apex SE
'11 Apex XTX
Thx
'11 Apex
'11 Apex SE
'11 Apex XTX
Thx
SledFreak
- Feb 7, 2005
- Ontario. Canada
600lbs dry.... The SE is 10lbs heavier then the 06-10 Attack/LTX.... This is what my dealer told which came from a rep.... I would assume the XTX is heavier...
Sno Cat
I’m surprised it’s only 10lbs heavier, would have thought 20. I found some old notes: Wet weights, no fuel, actual:
604lbs ’07 Attak
585lbs ’07 Apex ER
Still curious to see if anyone's weighed the '11's.
604lbs ’07 Attak
585lbs ’07 Apex ER
whitedust1
- Jan 10, 2008
- Waterford ,WI
- 2012 Apex XTX
Once a heavyweight always a heavyweight Yam knows no other way.lol
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
In the manual it gives their wet weights. XTX was 699. std was 691 and SE was slightly less, don't recall but around 5# I think less. I think they are fudging them by about 20-25 lbs. XTX weighs as much as a Z1 turbo does wet weight. 725 pounds, and the Apex only has a 9.1 gallon fuel tank.
The 2011's are just shy of 40 lbs heavier then the machines they replace. 38 lbs to be more exact.
Super Sled
- Feb 25, 2009
- Summit X
Does it really matter. Plan on carrying it anywhere? That worried about not coming close your truck's towing capacity?
Turk
Tech Advisor
Carried a lot more doo,s then yammies. They even tow heavy.
sx7001
- Jun 28, 2003
- Sidewinder
SledFreak said:600lbs dry.... The SE is 10lbs heavier then the 06-10 Attack/LTX.... This is what my dealer told which came from a rep.... I would assume the XTX is heavier...
I weighed my standard Apex (128) the day I picked it up. 616lbs with 2 bars on the fuel gauge.
SledFreak
- Feb 7, 2005
- Ontario. Canada
Turk said:Carried a lot more doo,s then yammies. They even tow heavy.
Mike, I see you in your profile, you have "bring on the 1200s".... How do they perform against your modded Nytro and your new Apex?
Turk
Tech Advisor
nytro is gone but with 2k mods on the doo,s(pc5/header/exhaust/clutching) they would slowly walk my nytro on top.
The xtx just walks away from the modded ones & runs from the stockers.
ApexSE/Vector
- Dec 12, 2010
Manual wet weights XTX 699 lbs., Std 690lbs. and SE 681 lbs.
Weight of liquids:
Gasoline- .711kg/l X 34.6L=24.6 Kgs.
OW30 oil- .845kg/l X 3.8L = 3.211 kg
60% Ethyl glycol- 1.09kg/l X6.2L x .6 = 4.05 kg
40% water - 1.0kg/l X6.2LX .4 = 2.48 kg
75W gear oil- .859kg/l X .25L = .215 kg
Dot 4 Brake fluid- 1.047kg/l X .35lL? =.3665 kg
Total Wgt.(not incl. shosk fluid) =34.9225kg
1 kg =2.2046lbs. x 34.9225=76.99lbs
Weight of SE(w/o shock fluid) 681-77=604lbs dry.Ball park guess of oil in 2 Fox Floats and 1 Mega Float at 10? lbs and maybe 2 lbs of grease for a svelte total of approx. 592 foe the SE if I haven't missed anything.
Weight of liquids:
SledFreak
- Feb 7, 2005
- Ontario. Canada
Turk said:nytro is gone but with 2k mods on the doo,s(pc5/header/exhaust/clutching) they would slowly walk my nytro on top.
What about ther etec 800 (broke in)?
Terminator
ApexSE/Vector said:Manual wet weights XTX 699 lbs., Std 690lbs. and SE 681 lbs.
Weight of liquids:
Nice job, thanks for the breakdown!
