3 1/2" riser?
zoomer
North Dakota
Has anyone put a 3 1/2" rox pivot riser on an 07 Apex Mtn before? Or is it even possible without extending cables?
A 2" will definitely work with no extensions.
A 2.5" that pivots (if anybody makes one) might work if you want your bars really forward.
I have a pivoting riser that replaces the whole stock riser from the base mount near the tank up. Wish I would have gone with the simpler ROX style. I've had several exciting moments where my bars suddenly ended up in my lap after a big bump/hit. This is a very bad thing when you are climbing the sort of things you can climb with boost...
I have a 3 1/2" Rox on my 06 stock cables. Its all in how you route the cables. Seen 5 1/2" with stock cables. The TPS will let you know if you got it right. Good Luck You can do it.
Biggest problem is the throttle cable and choke because there isn't much you can do to re-route them, atleast there's not on a rx-1. The wire harness can have the zip ties cut on it and then pulled up a bit, once again if it's in place the same. The brake lines should be easy to re-route no matter the sled.
