5DM Oil Filter measurements
JohnWI
S Central WI
Anyone getting ready to change that filter this year?
If you've got the 5DM filter, could you post the length and width, please?
I've searched the posts and it sounds like no one has posted the dimensions yet.
I'm a Pure-One fan. I've got an idea as to which one will fit, but thought I'd see if anyone has the exact size of the Yami filter.
Also, how much room is there to spare for clearance? ie if the "replacement" was 1/4 - 1/2" longer, would it still clear, or is it that tight inside the frame?
I know other models use a filter with a "g" in the name, how much longer is it that it won't fit?
TTT
I know some of you have got to be ready to admit the snow's gone and it's time to change the filter.
I'm looking to put in a PureOne PL14612.
It's 68mm across and 76mm tall including 1mm for the gasket.
Hoping to know it fits a Rage and Vector before I make the trip up north to change them.
My two 04 & 05 RX-1's and my 04 Royal Star Midnight Venture bike and my 400 Kodiak all take the same filter. I use the Hi flo 303 and is a direct cross reference to the yamaha filter. I just measured it to be 2 7/8" high and 2 5/8 round. That filter will fit as long as the threads are correct.
PART NUMBER: PL14612
PureONE features exclusive MICRONIC® Filtration media that traps even the smallest particles of dirt and grime before they get to your engine. Particles too small for conventional filters to catch. Which is why PureONE is the top ranked filter in SAE tests at keeping your oil pure. And why no other filter provides better protection for your engine.
Specifications
Relief Valve P.S.I.: 14-18
Type of Filter: Spin-on
O.D.: 2.69
Anti-Drain Back Valve: Yes
Threads: M20-1.5
Height: 2.93
