rx1turbo
- Jan 6, 2007
- Burns Lake British Colombia Canada
05 rx-1 mc-express rear mount turbo running 12 boost with a 162x2 1/4x3pitch track need some gearing and clutching help for the snow drags have to stomp on 1500cc cat
Any help would be great!!!
snowy1
where are these snow drags being held, turn the boost up I don,t think 12 lbs, will get it done, if you don,t have it better put alittle nitrous to it. that will help out of the hole, I have used strait 47 and 54/47 both worked very well, abu-oo,s loaded for 12lbs, weld on the tip if you turn up, or supertips either one will work. around 2.0 on your gearing should work.
NORTHERNAPEX
- Nov 3, 2005
i think your going to need more than a little gearing and clutching alone. My suggestion is to shorten the little rod on the turbo and add some good fuel!
rx1turbo
- Jan 6, 2007
How much boost ?
How much boost can I run with just 3 head gaskets and 104 octane to still be safe? Running at 2000 t0 3000ft
snowy1
if that is actual 104 octane not 104 octane booster, should be able to run 18 to 20 lbs with that set up, and you will need it to beat a 1500. and with out some nitrous to get it spooled you still may not have a chance if he is set up right.
