Seems slow as all heck to me! Here is the list
05 Warrior
ECP Filter Kit
EVAC
HH's (Matt's suggested set up)
108 Down the middle
Stock Springs
Stock Helix
Stock Rollers
New Belt
Hits 10,400ish right from the wack of the throttle. Other stock Warriors were running 90+ with the same stud setup. I ran 92 Three weeks ago with the same setup and stock weights. Only Pulled 10,100ish.
Any Ideas?????????
05 Warrior
ECP Filter Kit
EVAC
108 Down the middle
Stock Springs
Stock Helix
Stock Rollers
New Belt
Any Ideas?????????
Prairie Dog
- Mar 3, 2004
different weather?
AIRWOLF
Guest
- Oct 1, 2004
- New York
- www.sledpartsgarage.com
Get rid off ,
Stock Springs
Stock Helix
Stock Rollers
Primary-use a mountain rx-1 stock spring
secondary use a stock warrior spring
helix 55/44
roller's 14.5 mm
Stock Springs
Stock Helix
Stock Rollers
helix 55/44
roller's 14.5 mm
Dano
Doesn’t hurt to try another belt. I gained a few mph by changing a new belt to an older belt. Once you find a fast belt, save it for the radar runs
RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
Well if your rx-1 is like my vector. It's your clutch kit. Mine knocked off 15 mph frpm top end. Switched backed to the stock weights and my top end was back.
- Sauk Prairie, WI
- www.ty4stroke.com
If you going radar running run the silver secondary spring. That stock white warrior spring will coil bind at full shiftout if its twisted anything past 60 degrees. Also, I mentioned in a pm to run 14.5 rollers and a different helix. Even with the white, Bill Morelli ran 100 this weekend with the exact setup I told you to run...BBY
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
BlueByYou2000 said:If you going radar running run the silver secondary spring. That stock white warrior spring will coil bind at full shiftout if its twisted anything past 60 degrees. Also, I mentioned in a pm to run 14.5 rollers and a different helix. Even with the white, Bill Morelli ran 100 this weekend with the exact setup I told you to run...BBY
So its a good idea to keep the stock Warrior spring at 60 degrees?
I presently have the O/S/O primary with tip weights removed and secondary set at 80 degrees (I think :? )
welterracer
Sounds like you were spinning hard off the line..
