CJW1
- Sep 9, 2014
- S,E Michigan
- 09 Nytro xtx
Can anyone tell me the location of the oil pressure switch on my 2009 Nytro xtx? Sled is occasionally flashing code 85. Would like to replace the switch but I am not sure where its at. Thank you for the help. Yes. I did a search for code 85 and there wasnt many replies to the 4 threads that came up. Thanks again
herndonp
- Nov 28, 2012
- Freedom,NH
- 2012 Yamaha Nytro XTX
Here you go. On bottom of engine by oil pan. Check your wiring connectors for corrosion or loose connection first.
Pete
Pete
CJW1
- Sep 9, 2014
- S,E Michigan
- 09 Nytro xtx
A very big thank you!!
