What parts do I need to add a 3 inch power madd block riser to my 05 Rage?
I assume I will need longer throttle, choke, parking brake and brake cables. Which ones do I get ?
I did a 3.5" Rox...Used the 05 RX Mt cables. Was able to re route the Brake and Park...only replaced the Throttle and Choke..although some people have gotten away with the original choke.
Thanks for the response.
How did you re-route the brake cables ?
When you replaced the choke cable, did it fit into the clamp by the carb's a little different ? I have a Mt choke cable and I have to clamp it on the cable as opposed to the metal end like the original choke.
