dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
I bought a snowcoach and need a hitch for my 08 Nytro that has a 136" tunnel extension. I see a factor hitch for 09 and up but not sure if they will work with the Hartman tunnel extension.
would an xtx hitch work better? might be able to reach the main tunnel and add some stregnth.
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
Not sure. There are aluminum straps that reach the main tunnel with the tunnel extension.
ok i just looked at images of the shorty and the xtx sleigh hitch. it looks like the xtx one is longer in the tubes and would place at least one bolt at the tunnel extension joint or farther in from it. the short track/mtx ones bolt in in place of the stocker with the bolts only on the tunnel extension.. i know how i am when i pull a sleigh and i would want at least one bolt on each side into the main tunnel to help prevent ripping off the tunnel extension.
hope this helps.
hope this helps.
dremmick
- Mar 17, 2011
- Savage, MN
- 2008 Nytro
hope this helps.
Thanks for your help I really appreciate it! Could you provide with the links where you found the pictures?
i just did a google search for fx nitro sleigh hitch and looked at the pics it brought up with descriptions.
