canadianhunter
When some of you adding additional idler wheels , how did you mount them?
I want to add a set on the out side of the rails about 5 1/2" ahead of the last set of idlers to prevent excessive slide wear. There is a hole in the rear end of item 18 [Frame, sliding c] that will work with the proper wheel bracket. Thought of using Item 27 [bracket 7] , but even when cut to length it is hollow and would be prone to sliding over the end of Item 18 and becoming cocked.
Would appreciate help.
ch
ch
