stohlem
- Jan 11, 2015
- 2017 Sidewinder LTX LE, 2014 Apex XTX
- Illinois
Hi Everyone, Just had first 9 mile ride on LTX LE 137. Love it! My question is,I thought I was getting rebound Clickers on all fours. Only see them on the fronts. Rear shock has a hex screw at end shock, but I think that's a fill hole. Was this another production change or am I missing something?
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
Front skid shock was only supposed to be a standard QS3 if I remember correctly. The rear shock is adjusted with a screwdriver I believe would have to check manual it says in there. It does not have the little knob like the front shocks but is definitely rebound adjustable.
Sent from my SM-G920W8 using Tapatalk
stohlem
- Jan 11, 2015
- Illinois
Thanks for the clarification.Front skid shock was only supposed to be a standard QS3 if I remember correctly. The rear shock is adjusted with a screwdriver I believe would have to check manual it says in there. It does not have the little knob like the front shocks but is definitely rebound adjustable.
Hex screw on the rod end would be rebound. There may well be another clicker for compression way down by the track as well.
Pstn head
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Yes,the rear skid shock has both,3 way compression clicker like all 4 has,but the rebound is a pain in the but to adjust,and it is a screwdriver blade slot only,on the front skid shock 3 way compression only,hope this helps,still going to be an awesome ride anyway we cut it.I did this, my fat head wouldn't fit between the tunnel and the rear skid. LoL
