After riding my RTX, i noticed i have very little ski pressure. How do you adjust to add for more ski pressure? Every corner, i was either sliding or lifting the front end with very little throttle.
The first thing to try is less transfer. After that you could tighten up the limiter straps one notch. What ever you try do it one thing at a time and remember what you did so you can undo if you don't like the results. The other thing most do is to add different carbides (6 inch carbide) or doolies.
