Adjusting ski pressure
To adjust ski pressure you can use the ski shock preload on the springs or air pressure if you have air shocks. More preload means less weight on the skis.
Next is the limiter strap in the rear suspension. Longer strap is less weight on the skis.
Then you have the rear spring adjustment. Softer setting on the spring means less weight on the skis.
Lastly is the transfer rod adjustment. More transfer means less weight on skis.
These adjustments will vary from sled to sled and what rear suspension it has.
Each adjustment effects ski weight at different times, crusing, braking, accellerating. Eric
