aduesling2
Hello,
I did search for this in previous forums, but could find nothing to do with MY seat. I added a Mountain Mod seat to my sled over the summer, and now want to put a riser on. How high of a riser should I use??? I don't want the bars to be crazy high, just comfortable. Thanks for the advice....
Yooper_Bob
Sit down on the new seat....stick your arms out to where you "want" to grab the bars, and have a buddy measure the height to the new position.
aduesling2
Will a stock Apex riser fit on? A friend of mine has one from his 2010 that he said I could have.... does anyone know what the size is on these? Also, does anyone know how high I can go before I need new cables? Thanks in advance, Al
Yooper_Bob
I think 2" is the accepted max that you can go before needing new cables.
Not sure on the fit of Apex riser.
I put a pivot riser and 4" block on my '05 Warrior...I was able to use the stock brake and parking brake lines with a bit of re-routing.
For the throttle cable, I bought an '05 Mountain sled cable, and swapped it out in 10 minutes.
jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
- 2010 RS VECTOR GT LTX STOCK FOR NOW!
Hello i went with a chux limited fixed riser 2" cheap easy to install and no new cables. i have an apex seat on the sled and its perfect. i also have one on my viper for the last 3 years no probems and super comfortable. i have a seat riser on that sled.
you can find him on ebay or google chux limited
I have a 8 inch Oles riser on my sled with a apex seat, I replaced all my cables with mountain stuff(witch is fairly cheap) and i also had to add some lenght to EVERY wire going to the bars to hide all the connectors under the hood. I think if i had a mountain mod seat it would be perfect, but with my soft gt seat i am thinking about going to the 6". Also i am 6'2"
