anti freze leaking behind primary cluth??
i searched anti freeze leak and it says may be front exchanger hose fitting at back of engine. That means engine has to come out??
You can get that hose back on, or push it further on the pipe, without removing the motor. you have to go through the access panel underneath, but it's a tight fit!
I noticed mine leaking and coming out around the clutch area and come to find out my reserve tank bolt had come out and tank was laying on top of head and all the fluid was leaking out. Fixed it and problem went away. If you take your side clutch cover off you can see in there with a flashlight.
