rancidjo
Is there any DURABLE paint or type of coating I can use for my ski loops? I would like yellow loops for my C&A outlaws, but they only offer black loops for outlaws
So if you know of anything that will work well, or of something you have tried and it did not work, do tell
.So if you know of anything that will work well, or of something you have tried and it did not work, do tell
200smk
I'm gonna try Krylon Fusion to do mine white.....
Vandelay Industries
- Apr 8, 2008
- Nashwaak Valley, NB
- 2013 Nytro XTX
I've tried the krylon fusion on many types of plastic. It bonds well with the plastic but if there is any amount of flex in the plastic, it will crack and flake off.
- Mar 1, 2004
Vandelay Industries said:I've tried the krylon fusion on many types of plastic. It bonds well with the plastic but if there is any amount of flex in the plastic, it will crack and flake off.
ABSOLUTELY
.....A sandblasted surface with a epoxy primer and a epoxy finish will hold up as I've done several over the years.
Send them to me and I'll do them in a 740epx Saftey Yellow for you if you wish.....Let me know?
- Mar 1, 2004
rancidjo
BOUNTYHUNTER said:Here check out the Flexablity in this panel as I've folded it right over several times........Didn't Crack
I'll do them for FREE if the YELLOW matches.
thanks bounty..pm sent...good to talk to you again
200smk
BOUNTYHUNTER said:Vandelay Industries said:I've tried the krylon fusion on many types of plastic. It bonds well with the plastic but if there is any amount of flex in the plastic, it will crack and flake off.
ABSOLUTELY
Could you do ski loops in white???
