Rash
I got a HX-C secondary with 42-34 cam and softest spring from yamaha... still hitting cutoff all the time at 11200 rpm... We're gonna put heel clickers on.. anyone got experience with this combo... starting off with the charts included with the yellow white spring included...
RASH
RASH
Charged RTX
Which arms do you have? One piece or two. If you have the 2 piece is it this years or last there is a big deifference.
Rash
Got the one peice.... the two peice just came out so i don't know them much
RASH
RASH
Turk
Tech Advisor
What are rpm,s now & how do you have them loaded. With this info I can get you very close with 1 change.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
I dont know much a bout the supertorquer secondary,but with the finish at 34 i would say its to much,try dropping back to 36 or 38 and starting with a 48 or 50 i had a roller by team on my 03 rx1 and it would start at 54 and shift to 34 and 36 but the motor was not designed to rev up like this new f-1 we have now,and my shift rpms on the rx1 was right around 10,400 try loading down the tip on your h.c. weights and if you are using there springs try a stock yammi primary spring.Rash said:I got a HX-C secondary with 42-34 cam and softest spring from yamaha... still hitting cutoff all the time at 11200 rpm... We're gonna put heel clickers on.. anyone got experience with this combo... starting off with the charts included with the yellow white spring included...
RASH
Charged RTX
I would recommend staring with the silver in the secondary at about 70 degrees. Or better yet the straight 42 with the yellow from Super Torquer.
Start with about 3 grams in the shoulder with the white spring up front. If you over rev on top and don,t have a 42 put 3 grams in the tips
Rash
Thanks, ill keep you posted with the results next week around tuesday it will be done, gotta work to pay all this
:exc:
:exc:
