RX Buck
- Sep 11, 2003
- Grand Rapids MN
- mobilepredictive.com
- 2017 Yamaha Sidewinder LTX
- MN
Our phazer has a leak in the chain case. It is very slight but is gear lube. Cant really tell where it is coming from, even after taking off all the panels. Is there a breather vent on these chain cases? The level is still full so I was thinking it may have been slightly overfilled and is coming out of the breather.
SharkAttak
the breather is in the dip stick, are you sure the dip stick is in right if not it could build up pressure and maybe cause it to leak
Aaron P.
When I had my FX in for the new tunnel, they found that mine was leaking and said it had a faulty seal. They also had one on the showroom floor that was doing the same thing.
pz5
chain case leak
mine leaked it was the little rubber groment that goes to the chaincase to the reverse gear box took it all apart and put black rtv and now it doesnt leak. the vent is built into the gasket not the dip stick.
