almond1000
- Jan 20, 2008
- North Fond du lac, Wi.
- 2017 sidewinder 2011 vector gt 2010 fx nytro 2009 vector gt
anyone know the torque spec. for the bolt that holds the primary clucth on a 2011 apex?
Main bolt is torqued 85ft.lb.to seat clutch then loosen and retorque to 43ft.lb.
TOMBOB
- Jan 20, 2011
- Saranac,Michigan.
- 2006 APEX ER
TORQUE SPEC
removal ccw or cw on the primary
TOMBOB
TOMBOB
almond1000
- Jan 20, 2008
I never had the clutch off the sled I just pulled the bolt and re install and re torque as part of the pre season maintenance. I do all the major fasteners every season on all my sleds. just my first time doing the 2011. so if I didn`t pull the clutch just the bolt what do i do? just torque to 43? the bolt removal is ccw
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Re: TORQUE SPEC
Lefty loosy and righty tighty.
TOMBOB said:removal ccw or cw on the primary
TOMBOB
Yes, if you have not broken it free from output shaft with a puller, then just retorgue to 43ft.lb. The 85 ft. lb. is to seat it on shaft.
