need info. pls advise. i have a 06 apex er stock with 1200 mls. i notice on trails that it wants to push around corners and darts all over the place. so if anyone can recommend anything i would greatly appreciate it. thnx
YamaTob
are you studded? try some longer carbides- also you could adjust your transfer rod, and your front springs
no studs! very short factory carbides, and would i put more load on the shocks or less??
UPsledder
I have 96 Studboy 1.375 studs with the .750 power tower alum. nuts down the middle. I put the Studboy 6" shaper bars on the front, but added the ski-doo ski-savers which fit perfectly. Four of us have the same set-up on our Atack and Apex sleds and have completely eliminated any darting or pushing. The other three rode Ski-doo's before this but say that these are the best handleing and best riding sleds to date. The one has a 04 Rev and says the Atack he has rides better in the rough trails than his Rev. Hope this helps.
welterracer
Dude..
get some 8 inch carbides.. 144 studs, and then post back..
I cant belive anyone would ride with those crappy 2.5 inch carbides
SSC89
Less load on springs at one-quarter turn intervales.
