NMYami
Does anybody have tips on how to remove the stock exhaust from an 07 Apex Mountain? Does the track and suspension have to be dropped to get to the clamps? Is there any easier way? Tips on seperating the the Y-pipe from the headers. I have heard this can be difficult. Any pics on removal would be great. I am replacing it with an aftermarket sytem. Thanks.
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
NMYami said:Does anybody have tips on how to remove the stock exhaust from an 07 Apex Mountain? Does the track and suspension have to be dropped to get to the clamps? Is there any easier way? Tips on separating the the Y-pipe from the headers. I have heard this can be difficult. Any pics on removal would be great. I am replacing it with an after market system. Thanks.
Remove the seat. On top of the tunnel, there are 5 little rubber plugs. You have to remove two of then to get the 2 clamps. loosen the clamps,( 12MM I think) remove the heat shield ( 4 bolts ) and remove the bolts holding the pipe towards the back of the sled, ( Also, 4 bolts ) Then just pull and wiggle, the pipe will slide right out.
-1CS
NMYami
Thanks for the reply. I have the exhaust out. Any tips on how to remove the exhaust gaskets from the y-pipe?
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
NMYami said:Thanks for the reply. I have the exhaust out. Any tips on how to remove the exhaust gaskets from the y-pipe?
You might have to just get new ones. The gaskets on my pipe were really in there good. I didn't even attempt to remove them.
Someone else may have a method tho.
-Vince
