RacerDave
This was taken out of a post on HCS:
"Along with the track damage, damage to the front heat exchanger looks to be another issue with some-and on the Yamaha Attack, it appears to be an extensive job if it needs to be replaced as the x-changer is a structural member of the chassis."
Can anybody comment on the structural part of the chassis and if this applies to a Apex?
waldo1
i tried to helearc one once - what a disaster - changing it is rough as well - ive repaired a few with some jb weld or this epoxy puddy called strong steel stick - its like a doughy 2 part muffler repair adheasive - clean and scuff up the area - you may want to insert some aluminium material if the hole is big and smoosh it in - ive done this a few times to mine and my buddys sleds and it has always worked - 1 sled has had it for 5 years now - or make an insurance claim and get a new sled -
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I have the JB weld on a front exchanger of an XTC for 7 years no issues works great.
Yamadoo
Yamadoo
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
just jb welded mine also.
yes it is a structural part of the sled but it isn't as big of a deal to patch as i am sure was said on hcs.
lift up rear end and place on a milk crate.
drain system. spray the area down with brake cleaner.
using a wire brush on the end of a drill. "a drill bit extension comes in real handy on this part." clean the area.
spray again with brake cleaner.
apply jb weld.
the job should take between 1/2 & 1 hour & costs aprox 10 bucks.
if you have major damage replace the exchanger
If you need to replace it then it is a pretty involved job but in my opinion the majority of holes can probably be pactched as i described above
apply jb weld.
ppwhite
I have 06 apex gt and put rock through my fornt heat exhanger .It is serviceable part .It is a big job finished mine this morning. Had to pull track ,jack shaft and chain chase. let me know if you need any help.Paul
- 6K
