slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
I was on a ride todaythe sled was running excellent I then made a corner the sled now does not move the belt is good however the secondary clutch spins all the way around I think I broke the chain does this sound right any ideas the sled made a funny sound like a high pitch whine noise.
trailhed1
Driveshaft maybe?
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
Ouch!!
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
It towed fine I'm not sure
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Maybe your chain tensioner loosened too much and slipped off?
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
How hard is it to pull case
karlburns
- Oct 3, 2013
- Anchorage,AK
- 2011 apex xtx
2010 vector ltx gt
Assuming your on an 06 not hard at all. Haven't pulled one on a newer apex to speak about those
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
Lot's of info here on pulling the chain case. Not hard. You'll need some tips and lot's of info. You didn't post your miles. This always plays into what could be the issue on these machines. Drive shafts are common in a way on 9000 plus... bearing could of went as well.
Good luck...
Good luck...
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
Sled has 8100miles and it is a 06 er
ShootToThrill
Prolly the chain. If you buy one find a team chain, they are borg-warner just like stock for about half the price.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
If the drive shaft broke up close to the chain case like they usually do, the secondary will spin freely. As you turn it you are spinning the chain, gears, etc. If you have a spare set of eyes to look under the sled, you will see the broken stub spinning where it exits the chain case.
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
Its in the trailer for the weekend till I get home will be taking it apart when I get home to find out what needs to be replaced
slowride06er
- Feb 15, 2014
- Ford River MI
- Apex
Is a Team chain is the same thing?Prolly the chain. If you buy one find a team chain, they are borg-warner just like stock for about half the price.
ShootToThrill
Yes hyvo chain from team is the same. Both are stamped Borg Warner
