JERSEYJOE
While I had my Apex on the lift I noticed that thte front lower A arm bushings were badly worn. Sled has just about 2000 miles. First I thought that the bolts were loose because when you shake the arm the bolt head moves. After taking the air box out to access the rear nut I found that the bolt WAS NOT loose. The bolt and nut are shouldered and tighten to a limiting point. The bushings are toast and the lower arms dance around enough to be a concern if I am looking to eliminate darting.
Anyone else see this? Dealer was no help.
TurboJamie
LOL they all have a ton of slop in them.
Bodacious
Check out your tie rod ends too, mine are as loose as a goose too, I noticed them being sloopy after only 1300 miles or so.
nate007
- Dec 25, 2006
- Iowa City, Iowa
- 1. '06 Apex -twin screw
2. '04 Redline Revolt 800
3. '09 Nytro XTX - twin screw
Should we be looking at replacement, or coming up with a solution? I haven't had mine apart yet, but I do have some slop in mine as well. I was thinking about some sort of bearing?
Nate
Nate
JERSEYJOE
SOLUTION
Yamaha should figure something out. What a poor design. I bet they are the same cheap plastic bushings in everything else. They should be brass at least. Ever work on a Polaris ATV front end? Brass bushings with a steel sleeve and grease fittings. Great opportunity for the aftermarket???
If you check yours you will see the bolts dancing around. How long can I ride if before the steel bolt begins to wear away the bulkhead?
One soultion: RIDE IT AND TRADE IT!
welterracer
There are a total of 12 bushings per side in just the A-arms and the Bulk head..
On my sled i replaced the bushings, and installed Grease Zerts in the A-arms to slow the wear down..
JERSEYJOE
BUSHING WEAR
AM I AT RISK OF DAMAGING THE BULKHEAD IF THE BUSHINGS GO AWAY?
welterracer
YES.... Replace them.. Its kinda tricky but do-able..
JERSEYJOE
bushing replacement
Don't have the time. Going on a trip have to do it when I come back. I was thinking on installing a wide kit next year. I wonder if the aftermarket kits use a better bushing or just the stock junk?
