apex gt, rear ohlins connection broke ????
apex_shug
Central Illinois
Notice the other day when ridding that the wire coming from the GT shock going to inside the tunnel was hanging real low with a BUNCH of ice on it. Broke the ice off, put it back up into place / tunnel clip and went on my way.
everything worked then
now i have noticed that both ends of where the shock wire and the wire running from inside to shock are broke underneath the skid / the ends. Guess it formed a bunch and just finally broke.
Question, will this hurt the shock if it run it this way / not hooked up?
Did you loose control on the display?
No it won't hurt the shock! With out the wire connected you will not be able to adjust the compression on the shock but the shock will perform to the last compression setting you had it on.
