Apex MPI stage 1 boost
crmac33
Miramichi NB
What is the max boost a stage 1 mpi supercharger can put out? What pulley combo would achieve this?
boost
12 psi is the max but I don't remember the pulley size.
If you are using a rotrex c15-60 (same as in nytro stage1) the max input shaft speed to the compressor is 11.840rpm
Example:
Engine revs 8900 (nytro)
34 bottom pulley
26 top pulley
34/26=1,3 (gear ratio)
1,3x8900=11638rpm (input shaft speed)
The standard pulleys are 27/24 on the stage 1 Apex kit. That should be around 12 psi and sea level.
