Apex RTX wont start!!
Timmins, Ontario
I went out to my fish hut and on my way back my coolant line near the bumber removed itself and leaked coolant, the thing nis the light came on and we ran it about 500 meters to my house and then shut it off...now the following morning we removed the casing and put the hose back on with the clamp and filled the coolant and bleed it ...the machine will turn over but will not start, it seems to ignite the odd time but then no luck
when i nturn the key on temp light is on and nothing on the LCD.
if you have any suggestion...it wouold help thank you!
Yes fuel pump comes on...your thinking it might not be getting the fuel it needs....its also kept in a heated garage. Just orange warning light is on the dash...
Check your plugs and see if it's flooded, never know.
Why?
Why wouldnt you pull over and let it cool down instead of risking damaging the motor? The light is there to tell you that if you dont stop you are going to do damage. If my light comes over I immediately stop and put snow on the running boards. I have only had it come on once - that was on a road without much snow.
