I looked in the FAQ's and could not find what is the best stud pattern and amount of studs for the apex with a 136 ripsaw, anyone?
apex4
stud pattern
i have a 2008 apex 136" & have 162 studs up the middle..only i can check crazy hook with my suspension adjustments & NO STUDS are pulled bent in 5390kms & i ride HARD...nothing hit exchanger either...hop this helps
my pattern is 3 across in middle..trying to get as many lines as possible..watch for the area around shock eyelet try not to get studs in that area...
