Since the past 3-4 weeks; when going between postings at a fast pace (less than 30 sec.), Always getting this message:
You cannot make another search so soon after your last; please try again in a short while.
Then must wait about 30 seconds, then press F5 to refresh.
Is that situation caused by system overload or Is there something else I can do to avoid this?
Thank you
Yummy
Thank you
Yummy
Crewchief47
- Jan 16, 2006
- McGregor, ON Canada
- 2008 Nytro MTX 45th
It would help to right click on threads you want to read and select 'open in new tab'. This leaves your search result page in one tab while you read the one you just opened. Benefits of this for you is faster surfing, benefits to TY is reduced server load.
I'm not using the Search option. I'm always using the 'View posts since last visit'. Message happen when going back after viewing a individual post to the main list.
Never did that before. I could try to right click and open the post on a separate window.
Tks
Tks
Swiss Sledder
- Apr 18, 2003
- www.mi5.gov.uk
Using the View posts since last visit is basically the same as using the search button. Use the technique Crewchief describes and you shouldn't have any problems.
