tshelver
Anybody use these? I'm thinking of a 2" lift on the Warrior along with 45 degree hooks to get a bit more leverage at the bars.
Or should I go with the mountain bars?
welterracer
I added a 1.5 riser and a 45 hook on the left side!! LOVE THEM..
2inch riser will pull too hard on throttle cable..
Snowaholic
hey welt,
where did you get the 1.5" risers?
Buckeye
- Lakes Region, NH
Who has the better 2" riser, Power Mad or Sportech?
sledheadgeorge
- Apr 28, 2003
- Which one? I have 6
Just order a new set of 05 handle bars, they are wider and higher by about one inch.
RobX-1
- Coldwater, OH
Snowaholic said:hey welt,
Snowaholic, Mountain Performance sells the 1.5" risers. I installed them as well as a pair of BJ Hookers.
http://www.mountainperformance.com/
Tork
RobX-1 said:Snowaholic said:hey welt,
Rob and Brian,
Is the 1 1/2 riser aluminum???????????????
I want to order 1 this week
RobX-1
- Coldwater, OH
Tork, I just went out and checked and I would say yes, it is all aluminum. Tried putting a magnet to it and it would not stick. Not sure if this would be the best to way to verify it but I'm sure a call to MPI would confirm this.
Snowaholic
Thanks for the info. Robx-1!
Blue Me
Sportech has the better riser. The PowerMadd one you gotta grind down. I'd go with at least a 2" and go buy the mountain throttle cable. The cable is only $18 and some change. And as for the hooks. I like the the aluminum handlebar knobs from Maxximum performance. You hang on and just rip!!!
