dmelectrician
Just curious what the big differences are between the three models. Been looking at the nytro line and really like it. The XTX long track seems great, but maybe not needed for me as I ride very little off trail.. RTX seems like a great sled, but do I need the RTX over the base model?? Does the RTX provide a better ride or is it jst set up better when ridden harder?? I ride alot of groomed trails and like to tool around the bumps and pits once in a while.. By the way if it matters im about 270 lbs..
Thanks..
Thanks..
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
big guy xtx more top end and better bump bridging...
2008FxNytro
- Oct 7, 2009
- Upstate, NY
- www.mpminc.net
I would vote same thing....XTX
I'm also 270lbs and the XTX works just great for whatever I want to do
dmelectrician
Thanks you, now time to look around for a sled.
stopdropanroll
- Oct 8, 2008
- Fall River WI
- www.styleonecustommotoring.com
Be prepared to re-valve your shocks with the XTX, I would say if you want a good ride out of the box a RTX would hold your wieght better. I am 6'6 250 with out gear and I bottom the front and center shock on a regular basis, the factory valving is very soft, don't get me wrong it rides nice when your cruising but when its late in the day and the trail turns into mogul city your going to feel the bump stops quite a bit.
