vmaxcrazy
Just was wondering. In my maintenace of the bearings on my 06 Attak, I messed up the seal on one of my bearings. It's the one behind the secondary. The bearing is fine, but I bent the seal badly putting it back on after regreasing it. I'm cheap and don't want to buy a new bearing and just use the seal or change out bearing as I'm really pressed for time. My question is does any one have an old bearing that they can take the seal off. Of course I'll pay for shipping and a small fee for the seal. Thanks in advance, vmaxcraz.
LJ 452
I should have my old bearing in the tool box. PM me your address and we'll figure something out.
LazyBastard
Why not pop the seal off and straighten it? There is a metal ring that is covered in rubber. Just whack it with a hammer until the ring is flat again and try to install it.
grader
buy a 6206 bearing and remove one of the seals. same bearing, but without the tapered bore, and inexpensive.
vmaxcrazy
Thanks all, I did straighten the seal as best I could, but just feel a new or undamaged seal would be better. I'll order the 6206 bearing and use that seal. Again thanks to all.
