Quince
- Jan 25, 2015
- 07 apex attak
Hey guys bought a used bender clutch kit for my 07 apex atack just looking on some help with setting it up as I noticed there's a few different settings on the helix and has heel kicker weights. Just wondering witch hole will be the best for groomed trail and ditch banging in the prairies. Plz help [emoji3] thanks in advance
Sent from my LG-H831 using Tapatalk
sgauthier
- Mar 5, 2009
- southwest, Ontario
- 2011 Apex XTX
for the heel clickers go to there website "www.heelclickerclutching.com" and go to the downloads/installation instructions for Yamaha. this should help you you out.
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
set the sec 3-3 or 6-1 and you should good to go have fun.
Quince
- Jan 25, 2015
- 07 apex attak
Thanks for the info guys got the clutch kit installed. Wanna pick ur brain one more time. When I installed the secondary spring put it to the 3-0 for trail settings as it said in the paper work provided. But when I run the kit the helix dose not touch the buttons when it's stopped did I not do it properlly? Or was that normal when it was stock I do not recall. Thanks in advance
sgauthier
- Mar 5, 2009
- 2011 Apex XTX
You're going to want more tension on your secondary. Not sure where you're getting the 0 from,that must be in the helix. Try putting it in the 3-3 like mentioned, 3 on the helix and 3 in the 2ndary then twist clockwise and push it into place. That should be a good place to start. That should give you more tension and seat your helix to the cams.
Quince
- Jan 25, 2015
- 07 apex attak
Ya ill give that a shot thanks just looks odd the way it is now.You're going to want more tension on your secondary. Not sure where you're getting the 0 from,that must be in the helix. Try putting it in the 3-3 like mentioned, 3 on the helix and 3 in the 2ndary then twist clockwise and push it into place. That should be a good place to start. That should give you more tension and seat your helix to the cams.
