ust421
I am just wondering if anyone thinks that this subframe can be straightened or not? And if so what is the best way to go about it?
hugger70mtnmax
Mine looked worse than that. It is easier to do on the sled but I did mine with it off. I just measured from the shock mount down to the rear of the subframe and made them match and then took a couple of measurements across the bottom to make sure it was square.
Then get you a kit from Grizztracks to strengthen it and you will be good. I just hit a rock hard enough to break a spindle and control arm and the subframe stayed straight. While you have the welder out weld the lower control arm nuts to the subframe on the very front and the very back. All four bolts are right in the middle then and it is a breeze to pull the arms off.
