big_red1a
Is there a riser out ther that will go from stock xtx height or slightly higher to mountain height +2" dont want to ask for too much but a pivot would be nice as well. I seen some under the accessories tab on the yamaha sight for a short time but they are gone I want to build a true crossover xtx i currently have rox risers 6-8 i think but it's not enough.
mud99
I just put on the Muffinworks 8" riser with the 2.5" Apex pivot adapter = 10.5" total. I doubt you could go any higher than this. I'm 6'3" and I can just peek over the top of this sitting.
If you wanted it to be adjustable, get the 2.5" pivot adapter from Muffinworks, and put on the rox 6-8.25" adjustable riser.
BTW, you will need a mountain throttle cable to get to this height and you will need to route it differently
Mark
Mark
big_red1a
The rox riser is what i have. I need more variable in the ajustment 2.25 is not enough. Any other ideasmud99 said:I just put on the Muffinworks 8" riser with the 2.5" Apex pivot adapter = 10.5" total. I doubt you could go any higher than this. I'm 6'3" and I can just peek over the top of this sitting.
Mark
04rxw10
- Jan 28, 2008
- Lisbon Falls Maine
- androscogginubm.org
loudelectronics
- Dec 1, 2007
- Souris, Manitoba
- presdwr.spaces.live.com
Talk to Rocky at Rox. He may be able to make you a custom riser. He has always been good for what I needed.
Nick1945
04rxw10 said:
X 2 On Lakeffect risers, I have them on both my sleds.
