michael432
was going to install a billet reverse handle on my wifes xtx but can not get the darn pin to come out. any suggestions--thanks
skoalring11
you need to put it in a vise and beat it with a hammer! The stock reverse lever hole were the pin goes thru is alot tighter then the billet one.
nytro addict
Yep X2 its a real pain in the
and you might want to set the handle and loctite it. Mine was just threaded on and wouldn't stay on. So I filled the gap on the inside and set it where I wanted it and then put loctite on it. Just a suggestion on the loctite. Have fun n good luck.
NLVMAX
- Jan 18, 2008
Check out page 3 of my thread. This is what I done.
michael432
thanks i will try it
