deerlodge
- May 1, 2003
- Orr,MN
- www.deerlodgeresort.com
Im going to be ordering billet T's tomorrow, do I need 4 or 2? not really sure which ones you replace.
Are the carb cap's really needed? mine seems to be fine the way it is. Im running around 14lbs with race fuel and mainly use it in radar runs.
Thank you
Rich
Thank you
Rich
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
you will need 2 t's and the carb caps help to keep the diagrams from blow out of place.Both are instock.
deerlodge
- May 1, 2003
- Orr,MN
thank you, will I need to sync the carbs when I put the T's on? I just had the shop sync the carbs.
also can carbs be synced off the snowmobile?
HURRICANE
- Oct 17, 2007
- Prescott Ont.
You shouldn't need to resink the carbs.They can be checked with a drill bit to check that all plates are at the same adjustment
deerlodge
- May 1, 2003
- Orr,MN
sending you a pm on the caps and T's^^
deerlodge
- May 1, 2003
- Orr,MN
Got the billet caps and T's thank ^^^
But when I pulled my carbs apart to install them I noticed the plastic T's nearest the motor were all smooshed. They must of been put in crooked when the carbs were apart last. talked to the dealer and the said atleast a week. I think they are part #
8fa-1410e-00-00. if you look at the carb scamatic the attach to #65 the candycane shaped hose on back of the carb. sorry I dont know the exact name of the part. I have a race next week and was hoping someone can get me one fast.
Rich
Rich
HURRICANE
- Oct 17, 2007
- Prescott Ont.
call me at 613 925 5171.I have carb parts to help you
