gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
I have a 06 apex gt I put a rear heat exchanger in I did not lift the sled at all put coolant in till a good stream of coolant came out put the bleeder put bleeder back in and add coolant to top it off i ran it it was ok took it out for a 3 hr ride want good am I safe or could there still be air bubbles in the lines I did not get out how do u bleed it the right way thank you
DTR 82-27
- Dec 22, 2006
- Drumbo, ON
- 2018 SIDEWINDER S-TX DX 137
I do the same procedure as you and have never had any issues. After getting the sled up to operating temperature, make sure the heat exchangers are warming up properly. Check up the right one, across the back and down the left one. If they all warm up properly, you do not have any air locks. Make sure the over flow bottle under the dash is topped up to the cold level line as well.
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
Ok ty Bc a lot of guy said u lifet the front of the sled
JStat17
- Dec 30, 2013
I just did the same. All heat exchangers warmed up and seems to flow as it should. I am still extremely dissapointed in the cooling system on my 06 apex er. 10 minutes of idling at 15 degrees and my temp light came on.....
Rich Kay
- Mar 29, 2006
- SE MI. Howell
- Yamaha apex rtx
Another tip is to be patient and fill it "slowly" .... this helps to not cause some air problems.
apex55
Did you use diluted antifreeze? Straight up doesn't work as well.
1320
Try Water Wetter it really helps ,you can find it at most auto parts stores , it stopped my sled from overheating.I just did the same. All heat exchangers warmed up and seems to flow as it should. I am still extremely dissapointed in the cooling system on my 06 apex er. 10 minutes of idling at 15 degrees and my temp light came on.....
JStat17
- Dec 30, 2013
I used prestone 50/50 pre diluted with 1/2 bottle of water wetter. I did flush the system and blew out anything that was left. I raised front end up above rear bleeder. Also for all of the do not mix Engine ice with standard coolant I mixed some in a jog and we will see if it gels at all.....Im not thinking it will.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
just need to keep an eye on it for first ride or two check coolant level and add if need be keep checking untill you dont need to add any.
