Blowin' Belts like an XP...
Youngton
Ellensburg/ Kachess, Washington
I have an 03 Rx-1 with a Bender stage 1 at 10lbs. Has a drop and roll, polaris primary and stock secondary, turnin just a 15 inch 162. Have gotten about 100mi to a belt and when they go, it blows apart taking out a water hose, wraping strings and rubber into primary so it wont release. After every longer decent pull i have smelled belt. The snow was not heavy. What could cause this to be happen? How can i fix it. Anything helps. :o| Thanks
I'd start with checking your alignment and offset. What are you running in the Polaris for weights?
