Ah, OK now I see why you are saying what you are saying...
I obviously can't speak for your sled,
and I certainly don't know what controller you have nor what fuel you are running nor what AFR you are getting, but I still don't think there are too many that will agree with you that as a rule of thumb you can "safely" run 9 psi boost at sea level with the stock Nytro fuel system and maintain 11.5:1 AFR, not on pump gas.
Certainly not one turbo kit company would...
And yes, there are other variables to take into consideration as well.
rlcofmn said:
10 lbs at 3500 feet on pump gas sounds scary to me.
Confused by the contradiction here, if you are running 9 lbs at sea level with the stock fuel system, then why does 10 lbs at 3500 feet sound scary? As you go up in elevation, the more boost you can run.
Are you running race fuel?
