snowmotion
- Nov 5, 2003
- BANFF ALBERTA WHISTLER BC
- www.snowmotion.com
Can the Stock RX1 mountain track be made to Work with Extroverts on 03 mountain?
BlgsRX-1mtn
- Apr 16, 2003
- Billings, MT
- '03 RX-1 Mountain LE
Yes it will work if you cut out the closed windows. Some have done this and not clipped the rest of the track also.
tundra
for me ,i just cut the window, perfect fit. Clip help more for friction than for traction with extro.
I cut all the window with retractable knife blade. Be careful to not cut anywhere except the window.
2 hours for the cut, with some beer,
LazyBastard
Just be careful to balance the beer with the 2 hours, otherwise it may take 4 hours and you end up with ribbons instead of a punched track :lol:
rx1forever
Oh yeah, especially if you like the hard stuff, like JD and coke!, like LB says watch the windows, have a good one
Kachess
I installed extroverts and punched the windows with a chisel. All worked fine except for a noise on deceleration. I finally installed clips on all the window to solve the noise, and still had it :? Finally realized the driver teeth were not meshing smoothly(hitting the clips and falling in) and filed the edge of the driver tooth, round, and no longer have the noise. Smooth as silk. Installing clips was a waste, but I'm not taking them off. Running the track loose makes an incredible difference in performance.
