black knight
Hi guys , I run Stud Boy douce bars. I like them and its geeting time to change
them. My buddy has the Woodys doolys on his Apex ltx. and they have a wider distance in between the carbides and they run a little higher on the snow.
Has anyone gone from the Duce bars to the Woodys doolys and what was your results?
thanks in advance.
Big storm on the way for the North East this week!!!!!!!
thanks in advance.
fourload
I run the 8" duece bars now and did run the Woody's 8"duallys. They both work to stop darting but the Woody's push too much in the corners! I like the duece bars much better.
RollRite
- Dec 16, 2004
- Pickerel , Wisconsin
- 2011 Apex
Get the woodys slim jims they wook great they are better than any thing else I tried
black knight
Roller have you ever used the Deuce bars from studboy. I really like the way it cornners now so i will probably stick with the studboy.
Thanks for the replys
This site is awsome for sharing info.
planner
Ran the stub boy and the slim jims; both worked on eliminating the darting, but still had the push in corners. Switched to the Bergstrom last year and no darting or push. The other big difference is the steering is easier with the Bergstroms than the other two. I have 3000 miles on these and they definitely good for the rest of this year. Some recent posts have mentioned not being able to contact Scott, so if you can wait I would order a set of Bergstroms in the spring at his pre-season pricing and he would ship/bill you in the Fall.
YamahaMainer
I just switched from woodys duallys (They might have been the slim jims but I can't be sure) to the Deuce bars and even after only riding on them once, I like the Deuces MUCH better.
I just bought an Attak with duallys already on them and on the first ride out I was actually scared to use the power under the hood because I found myself heading for the trees at every turn. The second ride I tossed on the Deuces and the first half of the day I found myself still wary going into turns but, even with loose fresh snow under the skis, I realized that I was actually able to turn! Thank you Stud Boy!
