Chain case drain plug?
Minneapolis
Hey guys...I've got the side cover off...but can't figure out where the drain plug is for the chain case. It isn't that little hex head about half way up from the bottom of the case right hehind the bottom of the brake disc is it?
Also...to pull the air box...do you just need to loosen the clamps around the carb openings?
Thanks! :Rockon:
The drain plug is inside the tunnel, reach up in there and youll feel it. To remove air box, loosen all clamps, disconnect strap on the front of the airbox then lift up from the front and disconnect the 2 hose clamps on bottom of the airbox...BBY
