Todd Beenen
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Yes, thats normal.
Todd Beenen
Cool. Thanks Knapp
Pstn head
I believe the rubber, plastic chain guides on the inside of the cover takes up the slack once reinstalled.
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Yes, That looks normal.
yamaha06
Is it recommended to change the reverse chain? I have 15,000km on my sled and have changed the main chain and gears as it was stretched and ran out of adjustment with the chain tensioner back when I had 10,000km on the sled. I was just thinking about this and wondering if I should be changing the reverse chain as well.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
IMO. No..... as long as reverse functioning properly..Is it recommended to change the reverse chain? I have 15,000km on my sled and have changed the main chain and gears as it was stretched and ran out of adjustment with the chain tensioner back when I had 10,000km on the sled. I was just thinking about this and wondering if I should be changing the reverse chain as well.
yamaha06
Sounds good, I guess the chain is constantly turning but never under really any load.IMO. No..... as long as reverse functioning properly..
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yea not much of a load on that. I think you would notice if the chain needs replacing. I can only say after 11500 miles on my 17 the reverse chain was fine. You got some good miles on yours also. If you plan to put double the miles you have now maybe buy that chain ? Depending on cost it might not be a bad thing to have on hand. I like having some parts on hand especially for sleds over 10k. But I would not replace it until you notice the reverse maybe acting slightly different.Sounds good, I guess the chain is constantly turning but never under really any load.
Turboflash
- Mar 18, 2019
- Southern MN
As you see, that reverse chain becomes looser as mile accumulate. No set mileage on when or if to replace chain but just know it's loose and when you go into reverse, be easy on the throttle.Is it recommended to change the reverse chain? I have 15,000km on my sled and have changed the main chain and gears as it was stretched and ran out of adjustment with the chain tensioner back when I had 10,000km on the sled. I was just thinking about this and wondering if I should be changing the reverse chain as well.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
So you’re saying put the sled in reverse and punch it? To check chain tension ?As you see, that reverse chain becomes looser as mile accumulate. No set mileage on when or if to replace chain but just know it's loose and when you go into reverse, be easy on the throttle.
Turboflash
- Mar 18, 2019
- Southern MN
Lol!So you’re saying put the sled in reverse and punch it? To check chain tension ?
