Blue Hornet
When braking slightly hard I get alot of noise coming from either the chaincase, brakes, or drive axle. I cannot really pinpoint it. I t almost sounds like the pads are falling apart. There is alot of growling and clunking where the clunking souds like its coming from the drive axle. Could it be my track is too loose. If you apply the brakes lighter the sounds do not appear. Im gonna look everrthing over but was just wondering if anybody else has had this problem. Thanks.
Zakre
Blue Hornet said:When braking slightly hard I get alot of noise coming from either the chaincase, brakes, or drive axle. I cannot really pinpoint it. I t almost sounds like the pads are falling apart. There is alot of growling and clunking where the clunking souds like its coming from the drive axle. Could it be my track is too loose. If you apply the brakes lighter the sounds do not appear. Im gonna look everrthing over but was just wondering if anybody else has had this problem. Thanks.
track tension could be it, check the tension first anyway could be racheting, does it sound like metal noises or just clunking plastic?
Blue Hornet
The sled is not ratcheting under acceleration, but I do have it set loose to help with slide wear. Some of the noise almost sounds like its the track skipping over the drive axle but I think overall it sounds like noises in the chaincase or brake caliper. I know I dont make sense. I was also riding an apex yesterday and didnt hear anything like that on his.
